Where is the Air Filter Located on 240s?
Old Sep 18, 2007 | 01:58 AM
buckquark's Avatar
Default Where is the Air Filter Located on 240s?
Hi, Im new tothe forums and new to owning a Volvo car. Ive refered to my owner's manual and searched online and I cant find anywhere where it shows where the Air Filter is located on a 1990 Volvo 240 DL. If someone could explain how to get to it or has any pictures of the engine with an arrow that would be great. Also tips on how to change it. Thanks
Old Sep 18, 2007 | 11:21 AM
Buphalo's Avatar
Default RE: Where is the Air Filter Located on 240s?
the air box is a black box on the drivers (left) side on the front, beside the radiator. to do it right, you need to disconnect the air hose from the front of the box, and there are two clips on the sides. pull the front of the air box out, be sure to get all the leaves and dirt out of the box, and put the filter in the front of the box first, making sure the rubber gasket is pressed in all the way around. then the front hooks into slots at the bottom of the air box (you can see the tabs when you have the front out). when you get done, make sure the gasket isn't sticking out anywhere around the box, or you'll be sucking filth into the engine.
Old Sep 20, 2007 | 10:05 AM
white out's Avatar
follow the intake from the throttle body to the airbox.
Nick
debargha
Feb 24, 2015 10:46 PM
shethe
Volvo C30
Aug 2, 2011 03:28 AM
shabraz123
Jul 9, 2008 01:07 PM
usedS70
May 28, 2008 08:11 PM
info2x
Feb 7, 2005 08:25 PM
