Where is Cabin filter located on a S70
Old May 28, 2008 | 08:53 AM
usedS70's Avatar
Default Where is Cabin filter located on a S70
Just bought a 1999 S70, need to know where the Cabin filter is located and how it is removed? A picture would be perfect.
Old May 28, 2008 | 09:11 AM
jsj_297's Avatar
Default RE: Where is Cabin filter located on a S70
I have a 1998 S70, mine was on passenger side engine compartment, near right strut tower. You have to take off wiper arms, hoses, and five or six screws to take off the cowl. You should be able to get to it after that, have fun.
Old May 28, 2008 | 03:20 PM
krudge's Avatar
um,yes its under the plastic cowl on the passenger side.
but u do NOT need to remove the wiper arms.
all u have to do is take the torx screws off {5,i think} and slide that plastic cowl down just enough {down past the lip of the "stripping" around thewindsheild}theto lift that one side of the cowl up just enough to access the filter.
its so SUPER easy to replace that filter.just did mine last week.
it snaps into the filter box.
lift up and backon the tab in the front of the filter{built into the filter}and pull it up and out to release the tabs in the rear.
i am assuming your car hasthe oem filter.
most aftermarket ones dont have the tabs and "snap tabs".
Old May 28, 2008 | 08:09 PM
usedS70's Avatar
Got it, wow was that thing clogged just as I had thought it would be. Condensation was building up inside of cabin because there was no air flow. This thing was full of debris and mold was forming. Napa wants $22.00 any where cheaper?
Old May 28, 2008 | 08:11 PM
usedS70's Avatar
By the way THANK YOU for the quick answer.
nigel_miguel
Jan 7, 2012 05:09 PM
bluemagicbus
May 17, 2011 07:18 AM
edahlgren
Oct 21, 2010 06:24 PM
Ahmed
Mar 28, 2008 04:22 PM
buckquark
Sep 20, 2007 10:05 AM
