where to find 34mm caliper
Old Mar 10, 2015 | 01:15 PM
dytha99's Avatar
Default where to find 34mm caliper
I need to r&r my rear brake calipers on my '89 740. Ain't had no luck finding anything but the 38mm calipers but i need 34mm. Any ideas?
Old Mar 11, 2015 | 01:23 AM
the parts catalog doesn't show any 34mm, just 36, 38, and 40....
it has the following PN's for Volvo rear brake calibers on a 1989 740...
3530755 marked 36 - LH
3530756 marked 36 - RH
5003512 marked 36 - exchange LH
5003513 marked 36 - exchange RH
3530757 marked 38 LH
3530758 marked 38 RH
5003514 marked 38 exchange LH
5003515 marked 38 exchange RH
9140392 marked 40 LH
9140393 marked 40 RH
Old Mar 11, 2015 | 02:37 AM
dytha99's Avatar
It's clearly marked 34...i did a search to see if a 36 could be used instead of 34 and came up with a vendor that had 34 listed for sale for a 1984 740. I'm thinking / hoping that will work. All the national part chains have 38 and 40 they can order but no 34 listed...kinda like what you wrote about part numbers.
Old Mar 11, 2015 | 02:05 PM
maybe you can put whatever is the more common on later cars, along with the matching rotors? I dunno why that wouldn't work. but then, wait, they all use the same rotors, so I dunno what the 34-36-38-40 refers to?? huh. later years were just 38 and 40
Old Mar 12, 2015 | 08:21 PM
jagtoes's Avatar
My 89 740 GL has 38's on the rear. FYI
Old Mar 13, 2015 | 12:38 AM
I don't understand why they aren't interchangable. the mount plates on the ends of the axles are the same, there's only one PN for brake pads and for rotors.
Old Mar 16, 2015 | 04:24 PM
zjinqui1k's Avatar
+1 pierce.
I'm pretty sure they're interchangeable. I once pulled a rear brake off an 850, and put it on my 240 as a temporary measure. It worked just fine, and I thought about leaving it as a permanent change. But the compulsive side got the better of me.
Old Mar 16, 2015 | 04:27 PM
the only thing i *would* suggest is, be sure both sides are the same.
Old Mar 17, 2015 | 04:49 AM
dytha99's Avatar
Yeah... I've come to believe that they are interchangeable. I believe the markings (34,36,38,40) refer to the piston size. And so long as both sides are the same you're ok. I ended up being able to use the 34's and now have a pair of 38's in the basement. Thanks for all the replies and your help.
Old Mar 17, 2015 | 02:44 PM
yes on the cylinder size. the 'repair kits' are specific to the stamped number, 36, 38, and 40 as the choices listed.
i don't see any cylinder size specific parts in the brake circuits, i thought maybe the proportioning valve might be different.
thullz
Mar 12, 2007 08:58 PM
lacrosse05
Nov 7, 2006 03:40 PM
satchmodog
Apr 13, 2006 08:02 PM
mywifescar
May 24, 2005 12:48 AM
floryed
Apr 8, 2005 01:11 PM
