White smoke, oh no!
Old Jan 25, 2010 | 08:51 PM
sandraqu's Avatar
Default White smoke, oh no!
I'm getting white smoke at tail pipe, and am hoping it can be stopped.
From the driver's seat via side mirror, I can definitely see the smoke when I take off from a complete stop (as in, a red light). The white smoke is more noticeable (to me) when the engine is at temperature.
A month ago the car use to start pretty fast (engine turned over 2-2.5 times and started right up), right now it's starting at about 5-6 turns.
I'll double check, but I don't think it smells of anything.
--sandra
Old Jan 26, 2010 | 12:10 AM
blue goose's Avatar
Possibly a blown head gasket. If you're lucky it's just a leaky radiator hose. Are you losing coolant? Better not overheat the engine or the aluminum head may warp and need replacement. If you have a trusted mechanic, have him do a cylinder compression test.
Old Jan 26, 2010 | 05:25 AM
sandraqu's Avatar
Blue Goose,
I do have a leaky hose, but how would that lead to white smoke at the exhaust?
I have a mild leak from the hose exiting radiator center left, and comes in just under the water pump (I've been told that's the water pump anyway), and above the belts on the front, left of the engine.
The water splatters onto the engine, at the base of the water pump. I've seen smoke emitting from that area, from the end of the hose specifically, as water evaporates. I'll replace the hose because it is bulging just before the metal tie. I'll check the tie later today for tightness.
Old Jan 26, 2010 | 11:33 AM
blue goose's Avatar
Sometimes, when a radiator hose or heater hose leaks, the steam comes out the back of the car while moving down the road and it appears to be coming out the tail pipe. You could have a friend follow you to observe if, in fact, the white smoke or steam is coming directly from the tail pipe. Better to replace both radiator hoses. When one fails the other one is on it's last legs. They're only about $5 each.
http://www.fcpgroton.com/category-ex...116/by_year/39
Pv12345
Oct 11, 2007 08:33 AM
V8SRSLO
May 9, 2007 05:57 AM
justben714
Jan 27, 2007 11:02 AM
jay philoon
Nov 6, 2005 03:41 PM
cool_guy_jay
Sep 27, 2005 10:35 PM
