windshield leak on drivers side...
Old Jan 30, 2013 | 09:38 AM
jayson44's Avatar
Default windshield leak on drivers side...
the last couple of rains I've noticed my windshield leaking about 6 inches up the A pillar. it doesn't seem to stream in, but it just sort of drips. but it goes back behind the dash, and ends up running down the fuse panel cover (LUCKILY it hasn't actually gotten the fuses wet...yet.), and onto the floor. my carpet is getting soaked, so maybe it's leaking a lot more than I think? it doesn't appear to be letting in lots of water...
are the 240 windshields prone to leaking like this? I read something about a clogged "rain drain" on a 940...do 240's have these drains? is there anything else to check?
also, I called a glass company about fixing it, and the guy told me that 240s have a windshield gasket and you have to replace the whole thing. he made it sound like if you remove the windshield it pretty much always breaks. I don't want to replace the whole thing just to fix a leak.
J.
ps. 1990 240 DL
Old Jan 30, 2013 | 11:04 AM
does this car have a sunroof?
sunroofs are mounted in a rain pan, which has drain lines down both A and C pillars. if these plug up, the water can find itself in places you don't want it.
and yes, 20 year old cars can have leaky windshields, and I think 240's are worse than many. newer car windshields, including 740/940, are glued in with urethane.
Old Jan 30, 2013 | 11:09 AM
jayson44's Avatar
no sunroof...
is the gasket thing true about 240s?
J.
Old Jan 30, 2013 | 11:55 AM
Travanion's Avatar
Not just 240s, pretty much all cars. Could be worse, you could be driving a VW Rabbit. Of the five I have had only one has not leaked on the fuse panel as of yet.
Old Jan 30, 2013 | 05:44 PM
analogies's Avatar
on my 79 242 there are these ducts right behind the hood hinges that I had to vacuum out 25 years worth of dog hair/leafs/dirt and mice droppings....the driver side one was incredibly clogged with dirt and leafs...and when I dug it all out...it seems that water escapes through touching the firewall and if there where any holes on the firewall behind the pedals it would soak up my carpet. Can't remember on later models though.
ToledoVolvo01
Apr 30, 2010 09:34 PM
Bruce Wayne
Jan 2, 2009 01:45 AM
vetalbig
Oct 22, 2008 07:34 AM
95pimpwagon
Jan 20, 2006 01:09 PM
kartman01
Nov 26, 2005 09:47 AM
