Wiring issues 91 940
Old Mar 24, 2018 | 07:43 PM
maxxmcdaniel's Avatar
Default Wiring issues 91 940
My alternator won't charge unless I jump it from the battery the only lights in my dash that work are high beam, and over drive. My temp gauge only works when I'm in over drive. Any ideas?? I haven't tried anything yet, I did install a new radio a while back. I've tested all fuses fyi. Thanks
Old Mar 25, 2018 | 01:09 AM
did all those things work before the stereo install?
Old Mar 25, 2018 | 07:43 PM
They didn't just suddely stop they stopped about three weeks after Install??
Old Mar 25, 2018 | 08:46 PM
jagtoes's Avatar
Can you recall when this happened and did everything fail at once . Also what wires were moved around during the stereo installation. How good is the battery.
Old Mar 26, 2018 | 04:17 PM
lev's Avatar
lev
Sounds like the circuit board of the instrument cluster went bad which happens often at this age, and all kinds of crazy things can happen. I'd refloat ALL solder points on the back of the board, see what happens.
Old Apr 1, 2018 | 11:36 AM
I re sodered the points it didn't do anything
Old Apr 1, 2018 | 02:44 PM
the 91/92 740/940 instrument cluster is problematic, and not directly replacable with any other year. my 92 had speedometer problems and even re-capping it didn't help, my guess is, the ITT 2015 speedometer chip was flakey.
but thats not your problem. I'd check out the ground block thats left of the drivers footwell and just forward of the door hinges, at the bottom. make sure every connection is good.
I'd also check the red wires from the 'positive terminal' to the ignition switch... on a 7/940, the positive terminal is on the firewall above the pedals, its a flat black box about the size of a box of chiclets, with a whole bunch of red wires attached... the plastic lid unsnaps...
for the alternator to start working, it needs juice on D+ to bootstrap the field coil... the ignition key supplies power when its in II or III to the batt/alt bulb in the instrument panel, then this bulb is connected to D+ via a thin wire. If its working, when you turn the key to II, the alt light comes on, indicating that bootstrap current is flowing, then when the engine starts and the alternator is generating power, the light goes out
skylonda
2001-2013 model year V70
Sep 10, 2015 11:00 AM
sdl92
Jun 22, 2013 07:19 PM
piv15
Jul 19, 2012 05:39 PM
Echoe
Aug 26, 2009 12:08 PM
Echoe
Engine & Internal
Aug 20, 2009 12:07 AM
