1992 Volvo 960 Relay Panel
Old Jun 15, 2007 | 04:37 PM
utjj99's Avatar
Default 1992 Volvo 960 Relay Panel
Hello,
Could anyone tell where you access the relay panel on a 92 960. I've seen some places that say behind the ash tray but when you take it out there is a solid plastic panel that doesn't look like it comes out that easy. Any tips. Why would volvo make it so hard to get to the relays?
Old Aug 22, 2007 | 11:32 AM
ppcgm's Avatar
Default RE: 1992 Volvo 960 Relay Panel
are you looking for the fuse box ? on my '94 it's on the left (driver's side) end of the dash, on the side so that you have to open the driver's door to get to it, then there's a panel with a thumb dimple like on your gas fill door, all the fuses and the like are under there and are numbered, there should be some spares in the bottom center pullout and a fuse puller nearest the steering wheel on the bottom
Mar 22, 2021 10:58 AM
jrcochranusa
Feb 19, 2010 02:30 PM
honeyfixthecar
Jun 7, 2009 06:17 PM
rviniczay
Jan 15, 2009 12:42 PM
danedeturk
Aug 23, 2007 07:03 PM
