1996 960 Power Steering Fluid?
Old Mar 19, 2014 | 06:21 PM
emacsp's Avatar
Default 1996 960 Power Steering Fluid?
I started hearing a whining sound from the power steering pump that lasts for a few minutes when I first start my 960 up. Checked the fluid level and found that it looked OK (pink color), but was a bit low.
When I checked my manual to find out what I needed to use for fluid replacement all it says is ATF. After calling Autozone and O'Rilley's I'm a bit confused because one said use Dextron III and the other said the car takes Type F.
Does anyone know exactly what should be as power steering fluid for my car?
Old Mar 19, 2014 | 08:20 PM
Either will work fine, I have used both in my 960. I think the '95 car says F but the '96 doesn't specify.
Old Mar 20, 2014 | 03:23 AM
emacsp's Avatar
Thank you Robert. I really appreciate your help, and I just subscribed to your Youtube channel.
allenzachary
Jan 14, 2012 10:01 PM
TheVolvoMan
May 27, 2011 02:28 PM
Jon391
Dec 5, 2008 08:33 AM
jruyle
Nov 21, 2008 04:12 PM
katiejoyful
Dec 12, 2007 04:49 PM
