1998 S90 vibration
Old May 28, 2006 | 03:23 PM
1998S90's Avatar
Default 1998 S90 vibration
Hello everyone. I have some kind of drivetrain vibration. It does it when I just rev the car and when I am accelerating. It is a little worse in reverse. At first I thought it might the engine or tranny mounts but I can't see any apprciable deflection in the mounts. How do you test the mounts? What other things should I check. The car has no stored codes. Thanks in advance.
Old May 29, 2006 | 01:10 AM
Default RE: 1998 S90 vibration
To check the mounts look at the oil pan by the Subframe.
If they are bad you will see the engine sitting on the Subframe.
The trans. mount look at the cross member and see if the Mount is sitting on the cross member.
jimmy6154
May 22, 2009 09:13 PM
amos
Sep 5, 2008 11:49 PM
ocean238
Apr 17, 2008 06:20 PM
Joyce
Feb 16, 2008 01:53 PM
Nelson
Feb 15, 2007 10:02 PM
