760 alloy window strips removal ?
Old Feb 7, 2011 | 05:28 PM
VOL-LO-VO's Avatar
Default 760 alloy window strips removal ?
Hi, 1989 760 model, anyone know how to remove the 6 silver ( or later black ) alloy / rubber strips that are sat on rear side panels / against glass, and 4 door tops / against glass, that look like they would bend if given no respect !!....uk workshop manuals no help here !
They dont appear to want to prise off, but i dont want to force, and for all i know they could be bolted and need inside door panels off.....so i thought i would pass this over to those that know hopefully on this forum !!....
If you want a smile or a laugh, it's all the same to me, check out pics of my volvo lowrider ...vol-lo-vo....if you've nothing better to do !!
Old Feb 7, 2011 | 08:54 PM
They are bolted inside the door panel.
Old Feb 8, 2011 | 07:02 AM
VOL-LO-VO's Avatar
Thanks for that info, can i take it that the estate rear trims likewise are bolted?.....or lift?
.....which means the rear side panels have to be remmoved, yes?
thanks again for any help.
Old Feb 9, 2011 | 09:24 AM
lev's Avatar
lev
On an '89, on the doors, I believe they are just pressure fitted, so they can be pried straight up. On the wagons, or estates, the very back ones, are held with plastic clips and to remove the moldings you have to pry them sideways, or horizontally-the front part is held to the pillar with adhesive tape.
Old Feb 9, 2011 | 11:59 AM
VOL-LO-VO's Avatar
Thankyou for your help!....bolted above doors....slide at rear ones....can your goodself or anyone add wether to slide to rear or front, info appreciated.
anyone know where i can get a new (old stock) silver set, (6), or as new set?
Old Feb 11, 2011 | 11:49 AM
akinsey's Avatar
bump! would like to know this info as well. (no shop manual either)
Old Feb 11, 2011 | 05:55 PM
lev's Avatar
lev
On the 740s the ones on the doors lift straight UP. The ones on the back have to be pried stright toward you (as you are facing them).
bachman
Jun 1, 2014 08:04 PM
Vmax
Nov 16, 2012 05:28 PM
RVAE34
May 27, 2012 06:52 AM
fast850r
Aug 5, 2010 04:16 PM
Bolbo
May 15, 2008 07:31 PM
