92 960 no start...
If it is the PNP switch, then you can remove it and clean out the old dried grease, and re lube it with a nice synthetic.
You may be able to start it though, I trick, that works for a while is to place the car on a flat surface, ignition switch on, press brake pedal and row the gear selector back and forth many times, 30 or 40. Then try starting it.
The rowing will clean the contact points inside the switch. Since it is located on the outside of the trans next to the down pipe of the exhaust the grease gets cooked until it binds up the small delicate springs on the contact areas. Cleaning and re greasing usually takes care of it. When reattaching the switch, there is an adjustment where the bolt passes thru, the slotted hole is the adjustment. With the car safely secured from rolling on jacks, set ignition switch to on, engine off, place gear selector in reverse, move the PNP switch until the reverse lights go on, now find the center point of the reverse light setting, then secure PNP switch. Try starting the engine, if it runs, then turn it off and and then place the gear selector in another gear but park and try to start it, it should not start.
Hope that is your fix.
DanR
DanR
I am guessing the fuel will be fine, look for a vacuum leak. Make sure the little rubber hose that connects to the idle valve is properly seated.
Check for cracks in the air intake, you might try disconnecting the MAF and see if that helps, also the temp sensor may not be sending a correct signal.
Those kind of things would alter the idle and make it miss. Could you also be lacking spark in some cylinders?
DanR
DanR
#17
the car sat for almost a year with only 6 gallons or so in it, i will check the vacuum lines etc, im pretty sure its firing on all 6 because with the starting fluid it would rev up to about 2-3k easy then die off, maybe idle really low for a few seconds. Its getting fuel i know at the rail when i got the car i put a whole thing of Isoheet in the tank, i also put a little bit of oil in each cylinder, i pulled a few plugs and they had a little bit of the oil on them that i had put in the cylinders.. i had to wire up a end plug for the coolant temp sensor,
#18
LOVEvolvos
04-23-2011 03:52 PM
