95 960 finally replaced the engine but,
Old Dec 1, 2009 | 04:28 PM
artesano's Avatar
Default 95 960 finally replaced the engine but,
Im having an issue with the starter motor, the connector where the thin blue wire goes is shorted to the engine and when I tried to start it burned my ground wire. Im trying to remove the starter motor but I cannot reach the screw that mounts the bracket to the engine. Maybe there is a procedure to remove the starter or I might need to remove something else before getting to it. Please advice!!
NOTE: Thank you DanR for your previous helpon changing my engine; it went well and I'm sure you will be proud of the overall work I did with the car.
T5-Rennen
Mar 16, 2013 03:42 PM
tork
Jul 16, 2010 11:43 AM
apfurste
Aug 11, 2009 06:44 PM
ocean238
Dec 23, 2007 05:43 AM
