960 ABS Light
Old Jan 5, 2019 | 12:26 AM
volvonewb97's Avatar
Default 960 ABS Light
So tonight I was driving home when my ABS light came on. I didn't have any problems when I got back, but in the future, is this something I should be concerned about and how can I get it turned off? Thanks!
Old Jan 5, 2019 | 10:59 AM
You need to check the codes to see what is causing the ABS light. It could be something as simple as a wheel sensor. Your 95 should have the OBD1 port with LED so you can do this on your own:
https://www.brickboard.com/RWD/volvo...rts_codes.html
Old Jan 5, 2019 | 01:26 PM
I kind of know about the OBD1 thing. In the meantime, is the car still driveable?
Old Jan 7, 2019 | 06:20 PM
lev's Avatar
lev
It is perfectly driveable, but if the light stays on you most likely have no ABS function while the brakes are OK... Go to a muddy or grassy or sandy area and try the ABS to see what you have in a way of antilock action--it doesn't take much. And do run those OBD codes to get an answer...
rcockerille
Aug 28, 2017 08:59 PM
PGH850WGN
Aug 19, 2016 09:02 PM
joefuss21
Oct 16, 2008 12:33 PM
tr_car_nut
Aug 5, 2008 08:59 PM
8T9GTA
Apr 27, 2007 10:49 AM
