chek engine light
Old Jan 9, 2007 | 01:37 PM
sharifsm's Avatar
Default chek engine light
how do I put the check engine light off on 960?
Old Jan 9, 2007 | 03:01 PM
sharifsm's Avatar
Default RE: chek engine light
I know it can be done from the dash board, but what is the procedure, do I need to have the car running or not . I pressed the swiitch with the car runnning and did not work.
Old Jan 9, 2007 | 09:15 PM
That will only reset the SERVICE LIGHT.
To reset the CHECK ENGINE LIGHT FOLLOW LINK.
http://www.troublecodes.net/Volvo/
Old Jan 17, 2007 | 04:37 AM
zmontgomery's Avatar
Service light: Pull the rubber plug out of the dashboard that is to the left of the trip odometer, take a pen and push exposed button. Check Engine light: Open the plug unit "A" above the driver side strut in the engine compartment. Plug the wire that holds the cap on into slot number 2. Press the button for more than 1 second but less than 3. The blinking red light will then flash whatever codes are present in the system. After codes have been displayed, press and hold the button for more than 5 seconds. The light should stay steady. Press and hold the button for another 5 or more seconds. The light should go out. Press the button once more for more than 1 second but less than 3, and verify that the ligh flashes 1-1-1, which will mean there are no codes present in the system. This will clear everything out and turn off the check engine light. However, if something is wrong, the light will probably come back on within the next 10 or so miles. Hope it helps.
Old Jan 18, 2007 | 12:45 AM
92volvo960's Avatar
I still cant reset my check engine light. The LED wont flash any code either. Just stays on. Any ideas? The car is running great and my gas mileage hasnt changed. I found a vacuum line that was disconnected, and i think that caused the light to come on in the first place. Fixed the line and now if i could only get rid of the light.
Old Jan 18, 2007 | 03:24 PM
is the light really bright? or dim?
Old Jan 18, 2007 | 09:33 PM
Make sure you have your radio code and disconnect the battery and reset the computer.
Old Jan 22, 2007 | 10:51 PM
92volvo960's Avatar
The LED was pretty dim. And i also disconnected the battery for about 30 minutes but the check engine light is still on.
Old Jan 24, 2007 | 09:10 PM
But can you read codes now?
Old Jan 25, 2007 | 01:43 AM
92volvo960's Avatar
No i still cant get anything other than a steady dim light. I called a vovlo dealer and they wanted $85 just to take a quick peek at it. Totally unwilling to help me with any advice if you can believe that haha.
Old Jan 25, 2007 | 08:28 PM
Maybe a bad ground somewhere.
Does the button feel springy?
Maybe the button is corroded and touching all the time.
Old Jan 25, 2007 | 11:30 PM
92volvo960's Avatar
yeah im gonna take a closer look at it this weekend.The button is still springy so im leaning towards some corrosion.
Old Jan 31, 2007 | 10:05 AM
he3r0's Avatar
get a OBDII reader, it plugs into console, near handbrake, and can read and reset trouble codes.
if you dont want tos pedt too much, try harborfreighttools or let me known. since I live in Raleigh NC
and i do have reader
Bye.
Old Feb 4, 2007 | 01:34 AM
92volvo960's Avatar
I dont believe an OBDII reader will work on a 1992. Pretty sure its 1996 and up. Correct me if im wrong.
Old Feb 4, 2007 | 05:36 PM
1995 is a split year.
OBDII is 1995 and later.
OBDI up to 1995.
tngreg
Sep 5, 2022 07:27 PM
s80kid
Jan 22, 2011 11:12 AM
gabyman97596
Mar 9, 2009 12:59 PM
ErnstlS90
Oct 23, 2008 08:37 AM
