Cylinder head torque spec question
Old 01-20-2010, 11:39 AM
kendogg's Avatar
Default Cylinder head torque spec question
The factory Volvo manual I got my hands on says 15 ft./lbs, then 45 ft./lbs., then 150*. Does that mean 150* in one rotation, or does it need to be done in steps?
Old 01-20-2010, 04:23 PM
silkhope's Avatar
My volvo service manual says 15 lbs, then 44 lbs, then 130 degrees. I take it to be in one pull, that is what I have done. Starting from center out
11 7 3 1 5 9 13
12 8 4 2 6 10 14 That is the # sequence of the cyl head bolts.
Old 01-20-2010, 04:40 PM
dan550i's Avatar
Yes, that would be in one turn. If this is for a 6 cylinder, I think the spec is 130 degrees, I know when I bought my green manual, it came with some updated stickers to apply on some pages to reflect a new setting for some torque values. And head bolts was one of them.
Make sure the bolts, bolt holes are clean, chased and you have oil on the head bolts.
DanR '94 964 347,000 miles (113,000 on the new engine)
Old 01-21-2010, 01:31 AM
Typhoon's Avatar
Also make sure to use new head bolts if specified. Most all engines that use an angle torque spec use stretch bolts and they really should be considered a one use item.
Besides, new bolts are just plain cheap insurance.
Regards, Andrew.
Old 01-21-2010, 07:15 PM
kendogg's Avatar
I have new head bolts, I know to oil them lightly (certainly not the first euro engine I've built, or overhauled), just need to verify the specs please.
Those 130* specs you guys are quoting - is that directly from a Volvo factory manual?
Old 01-21-2010, 09:20 PM
silkhope's Avatar
My numbers are from Volvo service manual # TP 31714/2 for the B6304 960 1991-
Old 01-21-2010, 09:24 PM
kendogg's Avatar
Awesome, thank you!!
Old 06-24-2013, 07:06 AM
Adrian P. Tate's Avatar
Default head bolt torque
Hey, I have a 95 volvo 960 & wanted to know if someone has the torque specs on the head bolts? I would appreciate any help. I've read several threads here, but, just want to make sure my model matches up.
Old 07-05-2013, 10:40 PM
Henry10's Avatar
You can find those values at the sticky on top,
Old 12-27-2017, 09:56 PM
Kingfish84's Avatar
do you know what settings r 4 aq115 head bolt
VolvoXC90Car
02-02-2013 11:05 PM
ivanprki
08-23-2011 08:45 PM
towjoe
09-02-2010 09:44 PM
texan_176
10-04-2009 10:05 PM
cb1313
05-23-2009 11:49 AM
Quick Reply: Cylinder head torque spec question
