960 Radiator
Old Nov 8, 2007 | 03:12 AM
darkdelta's Avatar
Default 960 Radiator
Hello Everyone,
New to the forum, owner of 1990 240 wagon, and 1997 960 wagon. I recently had need of replacing the 960's radiator. I just wanted to pass on the reason. When I was removing the old radiator, I found one of the two brackets that hold the radiator, loose. The brackets are secured by two 10 mm nuts, inside the bracket are the actual rubber mounts. The loose nut was on the inlet side and allowed the radiator to move, cracking the inlet port. I hope I am not re-inventing the wheel here, but is something to look at next time you pop the bonnet. I hope I can say this I ordered a Nissens, it installed with no problems.
Good luck to all
mikeawd850
Nov 30, 2012 02:26 AM
pruner1
Jul 21, 2011 09:32 PM
casozone
Aug 24, 2010 06:55 AM
ronananda
May 7, 2006 06:12 PM
copper2
Nov 23, 2005 01:41 AM
