960 relay issue
Old Jul 27, 2015 | 07:14 PM
Haunted 960's Avatar
Angry 960 relay issue
I had the random stalling issue with my 960. I went to check the main and fuel injection relays. When I did, both plugs fell apart, old insulator going everywhere. I managed to put one back together correctly, but the other has me at my wits end. The relay I am having trouble with has 2 red wires that always read 12 volts, a black and a green/black wire. I cannot figure out how to hook this back up. The part number for the relay is 3544322. It is located on the driver side of the engine compartment next to the main terminal. Any help would be greatly appreciated.
Old Jul 27, 2015 | 07:33 PM
VDonkey's Avatar
What year do you have? I will get you the wiring diagram so you can work on this.
The connector should only cost a few dollars, I might be able to get the part number for that too. The old wires & contacts will click into the new connector housing.
Old Jul 27, 2015 | 07:38 PM
It is a 1994 volvo 960.
Old Jul 28, 2015 | 05:57 PM
VDonkey's Avatar
Wiring diagram here
http://www.volvowiringdiagrams.com/v...20Diagrams.pdf
At the end of the contents pages is "List of components." This will help you make sense of the numbers in the diagrams.
Let me know if you can't find the color abbreviations.
Old Jul 29, 2015 | 09:48 AM
Thank you very much. I was able to get the relay rewired and the car is back up and running. This manual should be very helpful if/when more electrical problems crop up.
sleech
Jan 25, 2020 05:07 PM
rviniczay
Jan 15, 2009 12:42 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
bcullen
Nov 19, 2007 12:43 PM
utjj99
Aug 22, 2007 11:32 AM
