960 RPMs jumping, then stalling
Old Dec 31, 2011 | 04:51 PM
  #21
Henry10's Avatar
Originally Posted by bill960
Alright, I got under there this morning. The connector was clean, but the part number I got gives me a completely different sensor, with 2 wires rather than 4. This is the one I need to order, right?
Amazon.com: Bosch 15098 Oxygen Sensor, OE Type Fitment: Automotive
Yes. You can also buy a Generic 4-wire like this for $ 35 + shipping: Replacement USOS-4000 Oxygen Sensor | Auto Parts Warehouse
Old Dec 31, 2011 | 05:31 PM
  #22
bill960's Avatar
Ah, too late. The Bosch one should be here midweek anyway, hopefully that will solve the problem. Then on to the sway bar bushings. Really appreciate your help on this.
Old Jan 6, 2012 | 04:30 PM
  #23
bill960's Avatar
Alright, so not surprisingly, the sensor is seized up and I can't get it out with my O2 wrench. I have a deep socket and a breaker bar but I can't fit the socket onto the sensor because the heat shield above the cat won't allow me the clearance, but I can't see how to get the heat shield off. Any tips?
Old Jan 6, 2012 | 05:12 PM
  #24
Henry10's Avatar
Try soaking it first in PB Blaster. If that doesn't work, heat up the area with a torch. Try a crows foot. Install the new one with anti-seize.
Old Jan 6, 2012 | 05:23 PM
  #25
bill960's Avatar
I've got PB Blaster on it, the problem is getting enough leverage to put real torque on it. If I could get the heat shield off I can fit a socket, but the heat shield is attached with these circular-headed bolts I've never seen before, and I'm not sure how to remove it. Have you ever taken one of the shields off?
Old Jan 6, 2012 | 05:53 PM
  #26
Henry10's Avatar
Those are blind rivets, but you can try a crows foot on the sensor, and don't need to take off the heat shield.
Old Jan 6, 2012 | 06:14 PM
  #27
bill960's Avatar
True, just need to find one. I'll try that tomorrow.
Old Jan 7, 2012 | 03:36 PM
  #28
bill960's Avatar
Got the crows foot, finally managed to break the old sensor out. Installed the new one, took the car out for 20 miles or so varying speeds, no CEL and no problems. Hopefully that's the end of it. Thanks again for all the help.
Old Jan 7, 2012 | 04:12 PM
  #29
Henry10's Avatar
Hope you applied anti-seize...
Old Jan 7, 2012 | 08:10 PM
  #30
bill960's Avatar
Bosch sensors come with anti-seize applied, fortunately.
cpearson74
Jan 20, 2013 09:39 AM
cpearson74
Jan 20, 2013 09:34 AM
2001 S60 2.4t
Mar 4, 2012 11:05 PM
talbott357
Sep 6, 2007 08:03 PM
