960 window problems
Old Jul 11, 2010 | 04:59 AM
capt. caveman's Avatar
Default 960 window problems
Hi I'm having some problems with the rear passenger window on the family 1996 960. I tried the search function on the site but I couldn't find anything with the same issue as mine.
Anyways, since we got the car a few years ago the rear passenger window was always a little funny, it would roll down very slowly and often get stuck halfway and I had to either push it down or hold the power window button down and listen to the motor strain until it went down. The window would scream the entire time as it went down regardless of which I did to the point that people would turn to see what the noise was. I never had a problem rolling it up thought.
So, one day about 2 weeks ago the window just stops working all together. It doesnt move and I can't hear the motor going anymore. As this is where I sit in the car and it's summer, every drive in the car I'm a pool of sweat. Does anyone have any info as to how I can fix this or what the problem might be? Thanks.
Old Jul 11, 2010 | 07:19 AM
Sounds like the motor might have gone bad. Best thing to do would be to remove the door panel and check for power to the motor.
Old Jul 11, 2010 | 05:19 PM
Ok thanks, if it is the motor, is it difficult or expensive to replace. We are staying in a hotel for the next month while our new house is getting ready so I have no access to any tools apart from a hammer and screwdriver set. Should I just take it to the dealer?
Old Jul 11, 2010 | 05:56 PM
Dealer is going to be way to much.
If you have a volvo specialist in your area try them. They will be alot cheaper than the dealer.
Old Jul 12, 2010 | 06:24 PM
lgbdad's Avatar
If motor is bad it will be the result not the cause. Make sure window tracks are not binding causing motor to overheat and burn out. if windows go up ok, but bind going down often lubing tracks with silicone spray can help. Do all windows once a year as pm.
Good Luck
Old Jul 12, 2010 | 09:41 PM
Capt. Caveman, thanks for the laugh. Actually forcing the window down time after time is asking for it to get stuck there. I'm sorry, couldn't help not to see the humor in this one.
I would agree with Igbdad. You probably needed to lube the track or something in there. The door panel comes off pretty easy and I would guess you could get a motor and replace it with little tools. Possibly even the ones in the trunk, they go a long way with these cars. You should be able to pull the panel, loosen the motor, manually raise the window and secure the motor to keep the window up.
Again, thanks for the laugh.
Old Jul 13, 2010 | 03:19 AM
Your welcome rspi but actually the window isn't stuck down, it's stuck up which is the problem because it is so hot out, I would not mind at all if it was stuck in the down position.
Old Jul 13, 2010 | 06:18 AM
I think that is better, being stuck up. So I guess you have a problem with you AC??? If so, you may want to check the freon level. You can go by an auto parts store or Wal-Mart and get a freon charging kit and check to see if your freon is low. They have gauges connected to the freon bottles now. So once you hook up the bottle, if it's low, just give it a shot. They also have good instructions on it.
Hope that helps.
Old Sep 30, 2010 | 05:16 PM
rjohnson67's Avatar
I've had that problem before. Fixed it by lubricating the tracks with silicone spray.
Old Jun 30, 2012 | 02:09 PM
TBDSeattle's Avatar
For those that are interested, here are directions to take the panel off:
Door Panel Removal Instructions for Volvo 960
I found them helpful... Now I'm going to try to fix this same problem on my 93 960 driver's window!
Old Mar 15, 2021 | 10:48 PM
Olaf Storåsli's Avatar
Thumbs up Raise/lower Volvo 960 rear window via jumper cables
My '93 960 driver's-side rear window stopped working 1/2 way open.
To avoid rain getting inside, I was able to raise/close the window as follows:
1. Took apart switch to see 5 pins: black wire, 2 reds & 2 others.
(ignore all but black & closest red wire which power motor)
2. With car off I ran jumper cables from battery &
a. to lower window, I connected black to black and red to red
b. reverse to raise window
3. If window doesn't move, your motor needs replacement
Anyone know the next step? Clean/replace the switch?
Full disclosure: I dicovered above by first removing my door panel to
see where I could power the black & red wires from the motor. I took
apart connector near the motor and applied power via jumper cables
to lower/raise the window. Replacing the door panel I found I could
raise/lower the window at the switch as described in 1-2 above.
Old Mar 15, 2021 | 11:55 PM
lev's Avatar
lev
Obviously a bad switch. Cheap to replace. Cleaning doesn't really work and rarely go well back together once taken apart. You can try to clean the contacts, file them down a little if corroded but I'd get a new switch.
Old Mar 16, 2021 | 09:06 AM
Default Thanks!
Thanks! I found NO POWER at switch when car running. Also, neither rear or driver's switch move window. What could cause no power @switch(es)? Fuse blown, wiring,...? Perhaps 2 switches failing simultaneously is still possibie.
Thanks for your suggestion,
Olaf
John Clawson
Oct 24, 2012 05:56 PM
mudiver
Jul 2, 2011 12:04 PM
murph
May 24, 2009 08:03 AM
ryst8
Apr 12, 2009 09:47 AM
bixing
Mar 11, 2008 08:23 PM
