97 Volvo 960 Ignition switch wiring question
Old Dec 16, 2008 | 05:07 PM
alliancemotors's Avatar
Default 97 Volvo 960 Ignition switch wiring question
I have a 97 Volvo 960 wagon.I am in the process of replacing the ignition switch.Upon removing the plug from the ignition switch all (8 or 9) wires fell right out of the ignition switch plug.I need to know the order to put them in.Called dealer, no help.
PLEASE HELP!
Thank you...
Old Dec 16, 2008 | 05:21 PM
Default RE: 97 Volvo 960 Ignition switch wiring question
Hopefully this is the same as yours I only had it for a 96 not a 97.
Old Dec 16, 2008 | 05:33 PM
WOW!That was fast!I beleive this is EXACTLY what I needed.As long as they didn't change the wire colors between 96 and 97 this will work.THANK YOU!
Old Dec 16, 2008 | 05:38 PM
Let me know how it goes.
Old Dec 17, 2008 | 04:05 PM
I now have headlights,wipers etc.(wich I didn't have before)but no pulse to the starter or fuel pump.I Hooked it up the best I could but some of the wires from 96 to 97 are different.Any ideas?
Thank you, Barry
Old Dec 17, 2008 | 04:19 PM
Try this one it is for the 98 960,S90 is what it says so that makes me think it is the same as the 97.
Old Dec 19, 2008 | 02:30 PM
That was most helpful.Thank you.The car now starts and runs well.Trans. shifts through all the gears perfectly but the dummy light for the trans(Flashing arrow) blinks and so does the three lights on the shift console for trans. performance options.This was happening before I replaced the ignition switch.I was hoping the switch would correct this problem.What do you think?
Tahnk you, Barry
Old Dec 19, 2008 | 04:03 PM
You need to get the transmission codes pulled and cleared.
The lights flashing means there is error codes on the transmission.
Old Mar 6, 2018 | 09:34 AM
Ramon Brennan's Avatar
I'm having the same problem with my wire colors what about that picture you took down that said work for him
Old Mar 6, 2018 | 10:23 AM
Is a 97 960 Volvo I don't have a red wire I have a brown and yellow wire
Old Mar 16, 2018 | 11:05 AM
micael's Avatar
Tahnk you, Barry
Don't know how old this post is, or if you found fix. I have a 97 960 that I bought used. Drove it home with no problems. Next day heading 30 miles to a doctors' appointment before dawn, had the same issue you described. Pulled the owners' manual, and learned it was the overdrive solenoid not pulling in. Had the code cleared, and no problems for another week. Then it reoccurred.
After multiple trips to O'reilly's to get this code cleared, I purchased a code reader and started clearing it myself. It's either a sticky solenoid in the transmission (and there are a LOT of solenoids it there), or a problem with the computer.
Not willing to invest in either one since I have the code reader, and just clear it myself. Once the code is cleared, trans shifts into overdrive just fine.
Only happens the first 3 or 4 miles of a trip after car sets overnight. Once it's cleared, doesn't come back on until next day I drive it. And doesn't happen every time I drive it.
Hope this helps.
Scott
Dagaan
Feb 9, 2014 04:48 PM
Echoe
Aug 26, 2009 12:08 PM
Echoe
Engine & Internal
Aug 20, 2009 12:07 AM
