AC cuts off when accelerating
Old Jun 18, 2015 | 10:25 AM
bne's Avatar
bne
Default AC cuts off when accelerating
'97 960 sedan I recently bought ...AC works fine but when starting off from a stop the AC blower cuts off until I reach cruising speed and let off on the gas pedal....what is the issue here? Can it be repaired and if so what kind of parts are we looking at and how much labor is involved?...Thanks
Old Jun 18, 2015 | 07:46 PM
VDonkey's Avatar
You have a vacuum leak.
Old Jun 18, 2015 | 08:55 PM
bne's Avatar
bne
Ah yes ...Thanks...what typically is involved here...O rings ... hoses...seals? is it a labor intensive job?
Old Jun 18, 2015 | 09:54 PM
lev's Avatar
lev
Most likely it's the one way valve under the hood, in a line from the exhaust manifold to the firewall, usually a black/white job about the diameter of a nickel, cheap to buy and easy to change.
Old Jun 19, 2015 | 04:38 PM
bne's Avatar
bne
Thanks lev...I'll be looking for this valve and buy a replacement prolly made by the chinese aftermarket...
Old Jun 19, 2015 | 08:28 PM
VDonkey's Avatar
In my car it was one of the diaphragms on the heater box. TEST FIRST before you buy anything. The check valves are very easy to test. Simply pull them off and try to blow through them in both directions
You can do a comprehensive test of the whole system if you know how it works. I explain a lot in this post
https://volvoforums.com/forum/volvo-...16/#post409241
Read on from "It is a bit easier to check..."
Cheers
Old Jun 19, 2015 | 09:23 PM
bne's Avatar
bne
Thanks for that...will be checking it out...hopefully I can do this myself ;-)
Old Jun 19, 2015 | 10:50 PM
lev's Avatar
lev
The 760/960 are much worse for Climate Control issues than the 740/940...
Old Jun 22, 2015 | 02:44 PM
VDonkey's Avatar
I hope it's not one of the bellows, it took me all day long to repair that once I got the part. To replace that you have to go deep into the dash as if you were replacing the heater core.
das8track
Feb 5, 2013 04:51 PM
cndymyfrnd
Oct 2, 2007 05:10 PM
maitresaman
May 1, 2007 02:02 PM
Italiano86
Feb 3, 2007 10:25 PM
maitresaman
Apr 7, 2006 07:39 PM
