AC high and low side pressure
Old Jun 24, 2010 | 02:29 PM
pturner's Avatar
Default AC high and low side pressure
can anyone tell me what the normal AC high and low side pressure readings should be when checking with a set of guages? My A/C cycles on and off and the last time I checked the low side only with a freon fill kit it showed there was enough freon in the system. still does not blow cold and as I said the compressor cycles frequently.
Old Jun 25, 2010 | 11:29 AM
dan550i's Avatar
There really is no way to tell you that, all depends on ambiant temp.
The system is designed to hold a certain weight of coolant, so your system needs to be evacuated and then refilled with proper weight of coolant. Add too much and you will be popping hoses or worse. Can be dangerous too, there is no high side fitting either.
DanR
zloetakoe
May 6, 2021 03:16 PM
katman104
Jul 29, 2012 12:12 PM
Bimmerguy
Jun 18, 2012 11:45 PM
STREETFIGHTER50
Mar 12, 2009 07:29 PM
Patdon10
Jul 24, 2007 08:14 PM
