battery always die
Old Nov 18, 2010 | 02:12 PM
jomo60's Avatar
Default battery always die
Hi,
I want to start off by saying that my battery is fine. Every morning my battery is dead. So naturally I suspected a battery drain. After charging the battery I disconnected the positive cable and connected a test light between the positive battery cable and the positive post on the battery but the test light did not light. I opened up the door and the test light lit up showing a draw from the battery (from the dome light). I closed the door and the test light went off.
Can a short only occur after the car sits for a while? I'm at a loss.
One more piece of information. This all happened when my transmission up light started flashing.
Any help would be greatly appreciated.
Jomo
Old Nov 18, 2010 | 08:03 PM
dan550i's Avatar
Are you sure your battery is dead? Do you check to see if your lights or horn work, maybe it is your PNP switch and it is not allowing the engine to crank.
Also check your main ground for corrosion.
DanR '94 964 356,000 miles (122,000 on the new engine)
Old Nov 19, 2010 | 08:09 AM
jomo60's Avatar
Yes, the battery is dead. The dash board lights are very dim as is the dome light and the car does try to start, that is it cranks but it's not strong enough to start the engine.
Jomo
volvo2005s40
Aug 29, 2009 10:01 PM
TiggerCarman
Jan 5, 2009 09:10 PM
awecomms
Jan 1, 2009 03:49 AM
jdseattle
Dec 31, 2008 08:04 AM
