Best Volvo Junkyards in Hawaii
Aloha all,
We just moved to Hawaii from NYC and I got a 1993 Volvo 960 Wagon. In pretty good shape except that it got T-ed on the passenger side door and fender a few weeks before I got it. The frame is bent right where the door and the front fender meet. Window is not broken but goes down about half way with a lot of strain. The dash is a bit shifted or just snug and smooshed in. The door closes and locks but it needs a really good slam to close.
Please see photo below.
I'm looking for some advice on the best way to fix this. First, I've called a few junkyards around Honolulu and they don't seem to have much of anything for this car. Are there any hidden junkyards or other used parts stores that I can find in the island that might have volvo parts?
Secondly: Has anyone here tried straightening the frame themselves? With what results and what kinds of tools am I looking at?
Thank you so much! I look forward to your suggestions and hopefully many years of fun and valuable exchanges in this forum.
ilir
Damage
ilir
Damage
Thank you, mt6127! I did try car-part.com. I love that site. However, the closest I can find is San Francisco and as we all know, shipping to Hawaii is not cheap and most of the time they don't even want to to bother with it.
I was hoping there would be some junk yards in the island that are not listed.
Thank you!
Thank you!
First, this is the same as a 940 body--makes searches much easier. Doubt that Hawaii will have one in a junk yard but who knows?
This hit looks like it'd take some professional "frame" straitening, in quotes because these unibody cars don't really have true frame. Still, you need a frame machine to pull the metal back to where it should be--not easily done with home tools and frame work is costly!
Looks like you need a fender, a door and then the frame pull. Sadly, all of that if done right will be more than the car is worth, especially considering where you are...
ChopperMan, I'm not 100% sure the frame is bent but I assumed it was because there's quite a bit of an arc at the bottom of the a-pillar, as you can see from the photos.
I guess my question is: should I pull this caved in rocker or push it from the inside? I figured I can push it using a 2x4 and a jack leaning against a pillar or the wall in my car port. If I need to pull it though, what's the best tools for that?
Keep in mind, I don't need this to look perfect. I'd be happy if I can get the door to close without causing an earthquake each time and get the window to go down without all that strain.
Thank you!
Thank you!
Thanks, Lev.
Yeah, Like I said below, if I can get the door to close decently and the window to go down without much of a strain, I'd be happy. I don't need this to look perfect. In fact, even if it looks the same as now with the functionality improvements, I'd be fine. I can bang around a little inside the door panel to get the window to go down easy but the a-pillar and rocker might not be as easy.
Volvo structure is very strong! I had a helluva time trying to move a front rail down 1/2 inch. Couldn't budge it without hydrolics so I went to a frame guy. That bottom of the A pillar is your problem, you can remove the door and the fender and see what you have more clearly. A 2x4, come-alongs won't help you, you need serious pulling power and to tie the car down. But you can always try.
