Blinkers stuck
Old Jul 20, 2007 | 12:18 PM
d34thd34l3r's Avatar
Default Blinkers stuck
so my girlfirends 95 960 wagon
has a problem with the blinkers
when she turns them on
they just light up solid and dont blink at all
any1 have any ideas what has happened or how to fix it?
Old Jul 20, 2007 | 01:26 PM
billofdurham's Avatar
Default RE: Blinkers stuck
This is usually the turn signal relay not working properly.
I have searched my books and can't find its location but this link is for the S90, the follow-on to the 960 so I am guessing it is the same set-up.
http://www.volvo-forums.com/index.ph...ndicator+relay
Old May 18, 2010 | 01:34 PM
s90guy's Avatar
I had a similar problem recently where my right turn signal was stuck 'on'. The fuse was fine and all of the bulbs were lit. It turned out that the front turn signal bulb has two metal contacts on the bottom that had 'fused' together over time, causing the short. A new bulb fixed the issue.
Old May 22, 2010 | 09:49 PM
The old bulbs cause all kinds of lighting chaos, see this thread: https://volvoforums.com/forum/showth...parking+lights
bdougherty28
May 20, 2012 07:43 AM
jedjed
May 27, 2008 06:14 AM
victim
Nov 20, 2007 07:10 PM
Richard74
Oct 4, 2006 08:51 PM
southbaltimorevolvo
Jun 19, 2006 09:25 PM
