01 S80 T6 blinkers
Old Oct 2, 2006 | 07:52 AM
Richard74's Avatar
Default 01 S80 T6 blinkers
when we use the left blinker, it kind of stalls, or blinks real fast for a second or two, then goes back to regular cycles. The right blinker seems unaffected. Any ideas?
Old Oct 2, 2006 | 11:05 AM
master_pre's Avatar
Default RE: 01 S80 T6 blinkers
The blinker bulb could be going out.
Old Oct 2, 2006 | 11:10 AM
studd34000's Avatar
yeah it could be the blinker or it ould also be a relay or an shim
Old Oct 2, 2006 | 11:19 AM
Richard74's Avatar
I know from past cars that a fast blinker is a indication of a blown bulb; however, this is intermittent, and only for a second. If a bulb is blown, it should stay a fast cycle, not return to normal. It has a few times just paused and not blinked. I have seen on past posts the number of on board cpu's this thing has, and just am wondering what costly issue is waiting for me,......
Old Oct 2, 2006 | 01:04 PM
master_pre's Avatar
I had a turn signal issue that ended up being a software problem.
Old Oct 3, 2006 | 08:53 PM
Either the Bulb or the turn signal switch.
Both are common to fail.
Old Oct 4, 2006 | 06:22 AM
Richard74's Avatar
Tech, what ball park for a $ figure am I looking at. Annoying versus cost preventitive.....
Old Oct 4, 2006 | 08:51 PM
The turn signal switch I think is like $50.00 to $60.00 or so.
The Bulbs are pretty cheap.
If it just annoy's you then replace it when you can.
Usually easy way to tell if it is the switch is when it acts up move the stalk a little more and if it goes back to normal the switch is bad.
bdougherty28
May 20, 2012 07:43 AM
d34thd34l3r
May 22, 2010 09:49 PM
jedjed
May 27, 2008 06:14 AM
victim
Nov 20, 2007 07:10 PM
southbaltimorevolvo
Jun 19, 2006 09:25 PM
