Brake Lights Not Working
Old Mar 7, 2009 | 07:13 AM
stonepa's Avatar
Default Brake Lights Not Working
I have a 97 Volvo 960 Wagon with a lot of miles (although it runs and drives flawlessly). The brake lights have stopped working. The tail lights, back up lights, and rear fog light work fine. When I depress the brake pedal I can hear the normal 'click' of the switch / solenoid that I thinks causes the brake lights to come on. Is this a part that typically fails? Or could it be something else? Would a place like NAPA carry this part?
Thanks!
Old Mar 8, 2009 | 09:30 AM
I will bet the brake light switch is bad.
Old Mar 17, 2009 | 03:19 PM
art164's Avatar
Default brake lights not working
Change the burn out bulb relay. Very common on 940's
Old Mar 17, 2009 | 07:23 PM
stonepa's Avatar
Interesting development. I noticed that if the vehicle is in park and I push the pedal in any way the brake lights work. If in gear, and I push the pedal in and slightly to right the brake lights work. If in gear and I push the pedal straight down the brake lights DO NOT work.
glixons
Jan 4, 2015 06:15 PM
rspi
May 15, 2014 07:36 AM
Mellott
Jun 13, 2011 11:41 PM
BigAdam
Oct 21, 2008 10:01 AM
