changing front rotors and brake pads on a 1996 960
Old Sep 20, 2006 | 10:14 PM
dpm2340's Avatar
Default changing front rotors and brake pads on a 1996 960
can anyone tell me how or where there may be a web page with directions to change front rotors and brake pads on my 96 960
Old Sep 21, 2006 | 08:33 PM
Default RE: changing front rotors and brake pads on a 1996 960
It is easy to do.
Remove the 2 10MM allen screws that hold the caliper bracket to the Hub.
Slide the caliper and bracket off. Then remove the one 10MM screw holding the rotor on.
You might have to wack the Rotor good to get it off.
Then reinstall the caliper bracket. You might want to loosen and remove the lower 12MM screw holding the caliper to the bracket then install it back to the hub. Then push the caliper back and install new pads and you are done.
mcs11311
Oct 19, 2014 09:22 PM
brickrunner
Jan 15, 2013 07:46 AM
Tgrumley
Nov 27, 2010 12:14 AM
Calita03
Jan 8, 2009 03:39 PM
JohnTheodore
Apr 28, 2008 12:35 PM
