coil pack removal - 96 960
Old Sep 20, 2009 | 05:35 PM
rich nc's Avatar
Default coil pack removal - 96 960
need to change the plugs on my 960 960 wagon. removed the cover and see it has individual coil packs on each plug. after removing the ever-popular 10mm bolt...
is there a special way to pull up the coil pack? a pair of screwdrivers perhaps? or a special tool?
do i need to disconnect the battery?
do i need to disconnect the coil pack from the loom too?
ANY help would be greatly appreciated!
rich in NC
Old Sep 20, 2009 | 07:31 PM
Just pull the coil out with your hands!! Sometimes they get stuck in there but they can be pulled out.
Old Sep 29, 2009 | 02:37 AM
zmontgomery's Avatar
avoid excessive bending of the harness wires. I broke one of my wires halfway right at the connecting joint and it made the car run rough. It was a pain to troubleshoot, and when I finally did find out what was wrong, I had to make a new plug, because apparently the plugs are not sold as individual units.
Old Sep 29, 2009 | 06:45 PM
No but you can buy a wire that you splice in and then put in the plug.
I replace them all the time.
Old Oct 11, 2009 | 03:56 PM
rich nc's Avatar
Default thanks..and twist it helps
thanks, guys.. i found that twisting the coil pack after disconnecting the harness helps break the suction and they pull right off.
rileyimport
Dec 16, 2013 09:36 PM
Sir_Lance
Dec 29, 2009 10:11 PM
VolvoRaider
Aug 12, 2009 01:03 AM
trooperone
Mar 7, 2009 03:34 PM
diehardgator1
Oct 2, 2007 05:41 PM
