Crunching noise
Old Jan 8, 2009 | 04:04 PM
jsmoline's Avatar
Default Crunching noise
Hello,
Once in a while, when I am backing out of my garage, or anywhere for that matter, I here a sound from under the car that sounds just like running over a plastic drinking cup or aluminum can. Every time I have looked, there is nothing there. Strange one eh? Anyone got an idea on this one?
Thanks, John
Old Jan 8, 2009 | 05:06 PM
Default RE: Crunching noise
Year and model please.
Old Jan 8, 2009 | 05:16 PM
TIPSP's Avatar
Got Boost?
Ifit is the same car he was given then it is a 97 960
Old Jan 8, 2009 | 05:19 PM
If it is that car start by making sure every thing in the front end is tight including all bolts.
Old Jan 8, 2009 | 05:59 PM
jsmoline's Avatar
Sorry, it is a 97 960. I will check what I can on the front end. Doesn't sound like that's where it's coming from, but I am getting older.
Thanks, John
Old Jan 8, 2009 | 06:54 PM
There is a square plate over where the steering rack is. There is 3 bolts holding it on. If they are not tight they can make a pop noise.
Old Jan 9, 2009 | 07:44 AM
jsmoline's Avatar
Thanks, I'll check it out. I watched while my son backed straight out of the garage. We both heard the sound and he stopped. He asked, did I run over a coke can? It sounds exactly like that. I'm betting it's something like you said. Thanks again,
John
Old Jan 9, 2009 | 08:51 AM
Your wlecome. Also check the screws that go through the body under the hood into the front engine craddle. The passenger side is easy to see and get to with a really long extension but the drivers side is a Pita.
Old Jan 9, 2009 | 10:35 AM
jsmoline's Avatar
Will do. One more thing. In the maintainance record book, I see where it has been seviced at the intervals listed. Mostly by a Volvo service shop. Other than where is lists oil changes, all I can see is that it has been serviced. Would i be stupid to assume that they changed the timing belt and tensioner when they were supposed to etc? After all, they are certified Volvo people.
Thanks, John
Old Jan 9, 2009 | 11:09 AM
I would think they would have as well. But you might want to inspect it to be 100% sure.
Old Jan 9, 2009 | 11:45 AM
jsmoline's Avatar
Called the people who worked on the car. Found out that it was changed at 170,000 miles and was serviced regularly. That is a big plus. Thank you guys for your help and quick responses,
John
Old Jan 9, 2009 | 11:49 AM
No problem glad we could help.
ceepyou
Jun 16, 2011 02:17 AM
Boxman
Apr 30, 2011 06:13 PM
chimmychong
Apr 2, 2008 08:39 AM
ludeless
Aug 28, 2007 07:14 PM
