Crunching noise when accellerating and fully steering
Old Apr 17, 2011 | 03:26 PM
Boxman's Avatar
Default Crunching noise when accellerating and fully steering
When my I'm steering full to the right or full to the left and try accellerating only the tinyest bit, there's a weird crunching noise coming from the front wheels. A bit of a clicking noise, sort of as if you're repeatedly cracking a joint in your own body. When I accelerate, the clicking occurs faster and faster, relative to the speed of the wheels/engine revs (haven't figured out which yet).
It only happens when I steer AND accelerate, not when I'm only fully steering or only accelerate. The ball joints were also recently replaced (<6 months) so I don't figure they're the problem.
Anybody know what this is?
Old Apr 17, 2011 | 06:44 PM
MattyXXL's Avatar
CV Axle's are shot... if you look under the car behind the wheel, youll see the ripped boots.. easy fix... auto zone offers a lifetime warranty with their axles you could do both for around $150 plus core.. Unless you have a corperate account then you looking at $45 for the right and $55 for the left with out the core, but they will most likely have to order the left.. Just ordered mine on sat..
Old Apr 29, 2011 | 02:14 PM
Boxman's Avatar
Turns out you can't order those when you're not from the US. I'm from Holland, so that's a bit of a problem for me.
I went searching for some used axles, and found a Volvo-specialized car-disassembly company. They had some axles for the Volvo 850 according to their site, so I went and asked if they'd be compatible with my Volvo 850 T5 stationwagon.
He then asked if mine was attached with a bolt or a nut, so I went and took off the plastic cap in the middle of the wheel; there was a nut.
He then proceeded to tell me that his were with a bolt and not a nut, and would therefore not compatible
Stunned, I went on a search-crusade; what I found was that early models (<'95) had a M20 nut, and later models had a self-tightening M22 nut - no mention of a bolt.
I'm not sure what to make of it. Is he talking gibberish? Does a driveshaft with a bolt even exist for the Volvo 850?
Old Apr 30, 2011 | 06:13 PM
Boxman's Avatar
Bump. Summary of previous post: Do driveshafts with bolt instead of nut at the end even exist?
ceepyou
Jun 16, 2011 02:17 AM
petes99xc
Oct 17, 2009 07:20 AM
EUSTexas
Jul 19, 2009 04:22 PM
jsmoline
Jan 9, 2009 11:49 AM
