The Diagnosis :(
Old Feb 27, 2008 | 06:17 PM
zmontgomery's Avatar
Default The Diagnosis :(
A few days ago I was carting some people/gear around in my 93 960, we were pulling a lot of grades with a headwind, so the car was running between 3500 and 4500 rpms for several extended amounts of time. The other day I noticed it was leaking a bit of oil, and there was a fair amount that had blown back and "dotted" parts of the underside. I checked the level, and was 1 qt low. (it has been almost 2k since last oil change) Took the car to the mechanic the other day to have it diagnosed, and I was told that that it was leaking oil from the crankcase ventilation system, that all cylinders had around 125 psi, when they should be at about 170, that there was a minor knock which could be due to a partially collapsed piston, and that the leak I was getting was due to blow-by. I love the car and it runs great. Super smooth idle, revving, and gas mileage. It has 165k on it and I am religious with maintenance. Should I be super worried? try to get rid of it asap? or just accept that it has finally been "broken in" and keep taking care of it......maybe dump a can of "restore 6" in it and see what happens? Any input is appreciated -thanks-
Old Feb 27, 2008 | 06:58 PM
Default RE: The Diagnosis :(
Have the Vent box and hoses replaced.
That compression isn't all that bad as long as they are the same all the way across.
One of the vent system hoses could be clogged making it leak oil.
Old Feb 27, 2008 | 10:33 PM
Thanks tech, I'll ask my mechanic about it tomorrow
Old Feb 28, 2008 | 02:12 PM
I was also wondering, should I be especially concerned about a potential partially collapsed piston?
Old Feb 28, 2008 | 06:49 PM
They might mean worn rings.
Old Mar 4, 2008 | 02:59 PM
Hoses were all clear, and all the gaskets/seals looked ok, I was just having a lot of blow by. Mechanic said that based on the compression test, the rings were probably worn. It's funny because when I drive the car how I normally drive it (nice and easy) I get hardly any oil leakage, (just a drop or 2 every few days) and whenever I take it on long trips where I am driving at a constant speed for a long time, I have no oil leak out at all. It seems that as long as I don't drive it hard it doesn't leak much at all. Does that make any sense?
Old Mar 4, 2008 | 06:21 PM
You might still have a clogged vent system. The more you drive the more pressure builds up in the engine. Then is has to go somewhere.(Leak out as oil)
Old Mar 8, 2008 | 12:03 AM
That makes sense.......we'll she's running good and strong right now, and so far I have not lost any noticeable amount of oil. So I guess I'll just see what happens. Gotta wait another month or so for it to warm up enough so I can give the vent system a thorough check.
Old Mar 12, 2008 | 11:08 PM
gotta love some of the quirks with these cars......I just did a 400 mile drive earlier this week, and guess what? underside was dry, and I lost no oil. hhhmmmmm
Old Mar 13, 2008 | 07:19 PM
ORIGINAL: zmontgomery
+1
Old Mar 13, 2008 | 11:03 PM
.....and I averaged 25 mpg, which included various mountain passes with a pair of skis and snowboard on the roof
94_850T
Jan 29, 2008 06:00 PM
sirjinx
Oct 11, 2006 08:56 PM
dkh c70
Dec 22, 2005 09:40 PM
850forum
Dec 4, 2005 10:52 AM
