92 960 Passenger Side Windshield Wiper
Old Feb 29, 2008 | 10:07 AM
TaiPan's Avatar
Default 92 960 Passenger Side Windshield Wiper
The passenger side windshield wiper does not operate. However, the driver side wiper functions normally. What is the problem and what is the best remedy? Thanks.
Old Mar 17, 2008 | 02:45 AM
4ofHearts's Avatar
Default RE: 92 960 Passenger Side Windshield Wiper
well... I had this same problem recently with my 96 volvo 960.
it was easily remedied by lifting the hood and tightening a bolt that held the wiper arm base to the base). Be sure that you let the wipers cycle once before you do this to *help* ensure the motor is in the correct position, or you may screw it up when you start to use it.
Turn on your wipers on the lowest setting, get out of the car and look at your pass side wiper. if it looks like it's twitching, ever so slightly, it's probably that bolt. Turn off the wipers, and car to be safe, lift the hood(to get to the bolt) and just tighten it. Problem solved.
Let us know if that pans out.
rspi
Jan 11, 2014 06:22 PM
Incursus
Dec 15, 2013 12:58 PM
Dr.JellyFinger
Dec 17, 2011 02:39 PM
jdbs3
Jan 8, 2009 02:01 PM
95pimpwagon
Jan 20, 2006 01:09 PM
