Transmission diagnosis rebuild troubleshoot PDF manuals,save great info and help too!
Old Nov 19, 2006 | 11:07 PM
dannydoo's Avatar
Default Transmission diagnosis rebuild troubleshoot PDF manuals,save great info and help too!
OK Here is 2 awsome auto tranny pdf's verry usefull!
I need 1 helpfull body tho.
IN this first chart..Applied elements and position.
http://www.transtec.com/tech_insert/94659.pdf
It says what sprag ,selenoid ,brake band and clutchs are enguaged in each specific gear right?
If you look at reverse and 1st gear,they are both sharing the same brake band,clutch and sprag ,AM I right?
So if 1st is dead,then rev should be also and vice versa...RIGHT?? I mean mechanicly speaking.
Im having a reverse slipping problem,but its wierd,it dont slip like regularly,it grinds a little right at first as it slips,then it catches.
Almost like a bad starter or selenoid..You know how they grind then catch?It feels like the driveshaft spline is stripped right around the tire area somehow,BUT ONLY IN HIGHER TORQUE APPLIED REVERSE SITUATION......IS THAT POSSIBLE????????
Heres the other pdf.
http://www.volvoclub.org.uk/tech/ser...sDiagnosis.pdf
If you cant read the files, just download free adobe acrobat reader,"below" they are tiny files and real fast self installed.
http://www.adobe.com/products/acrobat/readermain.html
Old Nov 24, 2006 | 10:16 AM
Default RE: Transmission diagnosis rebuild troubleshoot PDF manuals,save great info and help too!
Sorry sir I don't know much about inside the trans. Never had one apart. We always just replaced the transmission.
Jakeness
Jul 22, 2022 11:07 AM
volv0850
Mar 5, 2015 11:07 AM
dneve85
Jul 24, 2013 08:11 PM
Kiss4aFrog
Nov 1, 2011 09:37 PM
the454
Jan 20, 2010 09:35 PM
