Door jamb seals
Old Feb 23, 2018 | 07:52 AM
va740twagon's Avatar
Default Door jamb seals
I got my new to me '94 960 on the road. I'll post a separate message about recent work that was done, a LOT of work all well worth it.
I've noticed that at least one of my door jamb seals has perished somewhat, a chunk of rubber missing in at least one place. Also I can hear the sound of road noise coming from a different door (passenger rear door) when driving down the road which sounds kind of like the window is not all the way up or the door is not completely closed but they are.
I'm looking for replacement door jamb seals perhaps also the rubber seal around the perimeter of the top of the door itself, and if available the rubber seals around the windows inside of the doors. I notice that the door jamb seal is what I guess is called b shape, the flat portion fastens behind the trim around the perimeter of the door jamb as seen in the attached photo.
Does anyone have any sources for rubber seals for the body? I'm interested in any information you may know about, including the doors, windows, and the rubber seal around the trunk, also the seal around the curtain for the sunroof as mine is separated from the curtain when I slide the curtain back. Suitable non OEM made replacements would be just fine and cheaper if the style of seal is available where I can cut them to length and join them at the corners. I've used the McMaster-Carr catalog in the US and they still have some seals of a few shapes.
Thanks.
moestr7v8
Feb 24, 2018 07:18 AM
systeman
Jun 21, 2015 09:15 AM
lesrrt
Sep 10, 2007 03:44 AM
elbert
Dec 6, 2005 01:18 AM
RLeighton
Jan 12, 2004 07:12 PM
