Door lock on 97 960 locks but won't unlock
Old Apr 20, 2006 | 01:09 PM
badbrad's Avatar
Default Door lock on 97 960 locks but won't unlock
Hi everyone, the problem here is when you unlock the drivers side door it feels like it is still locked and will not open. It will though unlock the other doors perfectly fine. I think something is loose in the drivers side door, i heard it could be a plastic clip or the whole rod. I was wondering if anyone knew of a service manual for me to take off the door panel and fix this matter. It would be greatly appreciated, thanks.
Brad
Old Apr 21, 2006 | 12:00 AM
Default RE: Door lock on 97 960 locks but won't unlock
The door panel is pretty easy to remove. First look under the bottom of the door panel you will see 3 white clips that you pull down. Then remove the inner door handle trim ring. Pop the cover in the Grab handle out(Where you grab to close the door) remove the 2 screws. Then you need to inspect the door safety light. Some are part of the door panel and some are a clip for the door panel. It will slide in and lock on a pin.
Then the panel should pull out and then up to remove.
brian0708
Jul 1, 2021 05:08 PM
Sssnake
Jan 9, 2014 10:15 AM
qcvol
Jun 17, 2013 09:55 PM
crgolf
Feb 10, 2013 12:43 PM
rcvolvo
Jun 3, 2012 02:25 PM
