Front end noise
Old Jan 22, 2009 | 08:02 PM
kzs983's Avatar
Default Front end noise
Hi, today whilst driving i noticed that there is a creaking noise that comes from the drivers side front end. When i got home i was pushing down on that side and i can hear the same noise. Struts and Springs were changed about 30K ago so im thinking its not that... any suggestions?
Oh i did turn the wheel to the left all the way quickly to see if there was anything obvious and i noticed that the rubber boot on what looks like a connecting rod of somekind was off( perhaps water got inand is causing this) it was attached to the strutt and went to a long bar that went under the car....
Old Jan 22, 2009 | 08:57 PM
Default RE: Front end noise
Maybe the outer tie rod is bad. That sounds like what you are explaining.
Old Jan 23, 2009 | 11:08 PM
kzs983's Avatar
Today i took my car to the shop and they threw it up on the hoist and they figure its the sway bar links that are bad.... They want $191per link+ labour. Does this sound right, that seems rather steep for 2 small peices of metal. Also they said that could be the cause of the noise but weren't 100% sure. I looked at them and it just 2 bolts off and pop on the new ones. Is that all there is to doing this, id rather do it myself than spend 450 bucks on a hunch. I checked out a few websites and i can find them in a set for about 50-75bucks from a company called Deutsche Parts. Are these any good?
Old Jan 24, 2009 | 12:23 AM
tedv's Avatar
That's what I'd do, DIY. It's not a hard job. Also check IPDUSA or Groton for pricing. Quality is OK from any of them.
Old Jan 24, 2009 | 08:02 AM
ORIGINAL: tedv
+1
Wing0
Dec 13, 2013 02:39 PM
scartydog
Jun 23, 2006 05:25 PM
Virginia Girl
Jun 14, 2006 10:42 AM
cbatterman
May 10, 2006 12:00 AM
ZIGZAG
Mar 17, 2006 09:34 PM
