Front strut replacement . . .
Old May 1, 2009 | 01:41 PM
rick311's Avatar
Default Front strut replacement . . .
Ive got a 1992 960 and it needs new front struts. i was thinking of just getting some kyb's to get the stock feeling. only problem is, ive got nivomat rear shocks.
Most of the kyb's i see say they exclude nivomats, but what would it matter? can i just get the kyb's for the front and not worry about the rears? i would really like some help here since this is something that needs to be done fairly soon.
thanks in advance.
Old May 1, 2009 | 03:09 PM
TIPSP's Avatar
Got Boost?
Yes you can replace just the fronts.....
I think you can convert from Nivo to regular shocks....but I dont remember how sells it.....IPD, FCP, EST????
Old May 1, 2009 | 03:38 PM
rick311's Avatar
so i can get pretty much any front strut and not worry about the rears? the rears dont need to be replaced, but the front ones do, BADLY!
so i can get these:
http://www.fcpgroton.com/product-exe...ategory_id/184
or these:
http://www.optionimports.com/hz3115-289.html
and still be ok as long as i dont touch the rears?
Old May 1, 2009 | 03:49 PM
TIPSP's Avatar
Got Boost?
I would get these:http://www.ipdusa.com/version.asp?st...=482&V_ID=1510
You have a 92....I believe it uses a Strut insert like the ones from IPD.....
Yes you should be fine with just fronts....Tech can confirm this for you though...
Wait for him to get on in a few hours.....
Old May 1, 2009 | 04:24 PM
rick311's Avatar
whats the difference in the ones you posted to the kyb's? are the ones you posted better?
i really appreciate the help here! youre awesome, and youre close! you live in moorpark? im from oxnard but live in encino!
Old May 1, 2009 | 04:41 PM
TIPSP's Avatar
Got Boost?
I am not sure what the difference is between the two....I believe Boge is the OEM strut provider????
Here is a question....they need replacing....Are you looking for Stock ride quality? or are you trying to find better handling/ with slightly stiffer setup?
Myself....I like Bilstein. I have the HDs F&R on my 745T. It is stiffer than stock, but I dont like the floating feeling some stock shocks/struts provide. The HDs as well as the KONIs give you a better handeling/ controll over all roads.
I know Moderator Jim, on this site, likes the Bilstein torunings they are a little stiffer than stock but have slightly better control.
What are you looking for?
Look through this link and see what will suit you: http://www.ipdusa.com/Volvo-940960/S...1-136-472-482/
Or find a site that has cheaper prices....
Old May 1, 2009 | 06:53 PM
rick311's Avatar
im basically looking for stock set up. its actually my girlfriends car. i would like for her to have a bit stiffer set up since she drives in canyons pretty often, but i know she wont like feeling the bumps in the road.
so yea, youve been extremely helpful! and i guess i gotta buy the inserts instead of the whole set up. hopefully tech will confirm like you said.
Old May 1, 2009 | 07:15 PM
TIPSP's Avatar
Got Boost?
All you need is the inserts....That is how these cars are designed....I will upload a pic for you to see. The insert goes inside the strut tube and everything goes from there....
Here you go:
Tech can help when he gets on....
Old May 1, 2009 | 10:32 PM
rick311's Avatar
Here you go:
dude, you are the freakin man!! this is going to help a ton!
i guess all i need to know if im goin to be ok if i have the nivomats in the rear.
Old May 3, 2009 | 01:26 PM
rick311's Avatar
quick question before i order these . . .
whats the difference between the ones you posted and these ?
http://www.ipdusa.com/version.asp?st...=482&V_ID=1511
just want to make sure i get the right ones. one says "automatic" and the other says "turbo gas." whats the difference?
nhadoulis
Mar 2, 2014 10:03 PM
RJSV70
2001-2013 model year V70
Dec 6, 2012 06:10 AM
scubatelco
Jan 29, 2009 09:48 PM
go2sharks
Jun 2, 2007 11:00 AM
