help 95 960
Old Jul 20, 2007 | 03:58 AM
currator's Avatar
Default help 95 960
i need help really bad i can not figure out what happened to the car i was driving it at about 62 mph. one night on my way home from work it was cool out not hot or cold and i had not been pushing on it or anything. now it has had a small oil leak for a while but i am always good on making sure its were it should be well anyway i was driving home and 3 miles from home while driving it like made a weird noise along with like a misfire or something then i started to slow down and my rpm were dropping and i started to hear a lot of noise from the engine in the car so i pulled over and the car sounded like it was gonna stall or blow upso i turned it off and checked the oil it was a little bit low so i add so more and i turned the car on it still sounded like it was gonna stall or blow upso i put it in gear and got it rolling again but i could not get it to go over 45 mph and if i tried to give it more gas it would start to make a weird noise and i would not go any faster oh by the way when i had to slow down to turn it was hell to get it back up to 45 mph it took for ever when i got home i went to park it and like it did not want to move any more fowards or backwards the next day i got it to start same noise but it moved a little bit and when i reved it a little it sounded kinda normal but after i turned it off it wont start now when u turn the key it sounds like its gonna start then it just turns over and over with nothing please somebody help
Old Aug 22, 2007 | 11:24 AM
ppcgm's Avatar
Default RE: help 95 960
what kind of racket is it making, and can you tell where the sound is coming from ? that could be a lot of things, from a catalytic converter to an electrical ground ... did any of the gauges do anything out of the ordinary ? ... otherwise, have you taken it to someone to pull the codes yet ?
LOVEvolvos
Apr 23, 2011 03:52 PM
RMK3
Feb 4, 2006 11:50 AM
vqmaxi17
Jan 17, 2006 09:11 PM
bluejohn
Engine & Internal
Dec 1, 2005 10:47 PM
mjtray
Jun 17, 2005 07:53 PM
