850 Turbo won't go faster than 45
Old Nov 27, 2008 | 09:13 PM
CrusherCurtis's Avatar
Default 850 Turbo won't go faster than 45
Ihave a 1994 850 Turbo My car starts runs and drives but it won't go faster than 45, like its not getting enough fuel or something. What could this be?
Old Nov 27, 2008 | 11:40 PM
litehwk356's Avatar
Default RE: 850 Turbo won't go faster than 45
check your fuel filter, and your catalytic converter may be clogged
Old Nov 27, 2008 | 11:58 PM
Could it be the turbo?
Old Nov 28, 2008 | 12:10 AM
TIPSP's Avatar
Got Boost?
Maybe...It could be a lot of things.
Can you try to describe it a little better? Any check engine light? when was the last maintenance/tune up? Is the car a stick or Auto?
Old Nov 28, 2008 | 12:51 AM
Arsenal6's Avatar
Well I don't know would you hear this since yours is a turbo...but I had that problem couldn't go over 30...does ur tachometer run normally?
Could be your exhaust manifold thats detached not sure how it happens but that was me 3 weeks ago.
Old Nov 28, 2008 | 08:19 AM
Psaboic's Avatar
I would also check the air filter. Actually, a decent tune up including new OEM plugs, air filter, fuel filter, and oil change should only cost about $100 and time spent. I would give that a shot first.
Old Nov 28, 2008 | 05:43 PM
JPN's Avatar
JPN
See my 2nd reply in the following thread for a tune-up item list:
https://volvoforums.com/m_48928/tm.htm
And as already stated, check for blocked exhaust creating an excessive back pressure.
JPN
rspi
Sep 22, 2014 08:42 PM
lyciwivyhef
Oct 18, 2013 03:12 PM
fattyearlman
May 25, 2010 03:50 PM
cool_kyle_3000
Oct 18, 2005 07:31 PM
