Just got a 960....1996
Old Oct 2, 2011 | 09:40 PM
  #21
mileycyrus's Avatar
" Many thermostats don't work, so people close off the air from the exhaust. This is important."
ok i get this, except for the part where the air comes from the exhaust?...the port side that the thermostat controls seems to be toward the front, which is the tube that wraps in front of the condenser......it came from Cali, and im in Fla., so the temp under the hood is always over 67 degrees....engine bays get hot...i dont get that. no matter what the temp is gonna be high extra tubes or not, only now it gets more air....i drove it all day like this with no problems...so i dont know...
Old Oct 2, 2011 | 09:43 PM
  #22
mileycyrus's Avatar
i could however plumb that tube back in...close the rear facing side off, and open that restrictive valve...that way its getting ambient outside air...that may be better if the sensor is that sensitive.
Old Oct 2, 2011 | 10:21 PM
  #23
mileycyrus's Avatar
ok ok...just looked at it all again to see how it worked....sorry for seeming retarded.....so i pulled out the thermostat and used a screw to hold the door open to the front side, re-installed that Y and the tubing to the front of the condenser for now until i come up with a better solution...
Old Oct 6, 2011 | 11:18 PM
  #24
mileycyrus's Avatar
any idea why i would have a random shudder above 55mph, coming off the gas pedal....as if im losing spark for a second....mostly it feels like \its when im inbetween gears...
Old Oct 7, 2011 | 06:34 AM
  #25
Henry10's Avatar
Maybe a misfire? Check your spark-plugs. Check also your COPs (coil-on-plug), and especially their boots for cracks.
Thirdly, check the electrical connectors to the COPs. They are know to corrode and back out.
Old Oct 7, 2011 | 10:30 AM
  #26
mileycyrus's Avatar
ive actually done all of that, replaced the plugs, and checked all of that...everything looked good, and it runs great otherwise.....
Old Oct 7, 2011 | 01:08 PM
  #27
Henry10's Avatar
Any codes?
Old Oct 7, 2011 | 04:44 PM
  #28
mileycyrus's Avatar
dont know how to check.....i need a computer?....i have to do that..
Old Oct 7, 2011 | 08:51 PM
  #29
Henry10's Avatar
Get an OBDII Scanner/Reader. Or you can DIY one this way.
Old Oct 12, 2011 | 01:09 PM
  #30
Here is my pic of the EGR. And yes it does look like you have one: https://volvoforums.com/forum/volvo-...01/#post287339
Miley, from the looks of your VW, I know your neighbors breathed a sigh of relief when they seen that 960 show up, the car is beautiful. They have NO IDEA what you have in store for it. LOL I mean it, funny!!! If you really want to have fun with a car, trade the thing straight up with someone with a 850 T-5, and make it a wagon. Way easier to do mods on it and you will be like me and get a kick out of playing with people in a Volvo wagon and kicking their butts.
If you plan to own an older Volvo for longer than 2 weeks, yes you will need a OBD-II scanner.
Yes, reading this thread has been fun. Thanks for the laughs, especially your user name.
Old Oct 13, 2011 | 10:24 AM
  #31
mileycyrus's Avatar
THANK YOU!!....the VW is running now, but i just took off the MAF to clean it....and i friggan broke the sensor blade.....ugh....NOW I NEED A NEW ONE...such crap...
although did kind of fix the AC problem....i just cheated and plumbed the vacuum line for the vent, the red one, right to the white one from the motor....voila....AC from my vents....temp fix, but thats all i wanted for now.
Old Oct 14, 2011 | 08:08 AM
  #32
mileycyrus's Avatar
ok, new MAF is in.....no difference, i still feel the cut-out/shudder....
ill be looking at my coils again to look for cracks...
Old Oct 14, 2011 | 08:36 AM
  #33
For cracks and the wires backing out of the back of them. You really need to check codes, the computer will tell you which cylinder is missing if any. Once you find that out you can swap coil packs to see if the missfire follows.
Old Oct 14, 2011 | 08:45 AM
  #34
mileycyrus's Avatar
its strange, it only misses/shutters at higher speeds, over 55, and inbetween on/off throttle...its as soon as i let off the gas it bucks a bit...as if it wants to go or just coast...and usually in the daytime when its warmer......although sometimes it does it if i romp on it....passing gear under higher load.....
Old Oct 14, 2011 | 08:52 AM
  #35
How are your mounts? Do you think that the motor can me shifting or changing torque badly?
Old Oct 14, 2011 | 10:08 AM
  #36
mileycyrus's Avatar
nope....it runs perfect all other times....only upon letting off the throttle it bucks.....also, just drove it to work...switched from S, sport, to E.....Economy.....still does it...but not as bad....
another thing....the faster i drive...the harder it bucks/shudders.....feels like a spark cut as soon as the throttle body closes.....wierd..
Old Oct 14, 2011 | 10:24 AM
  #37
mileycyrus's Avatar
on another side note....the idle is great at startup...but after about 20-30 minutes it gets rough....dont know if its related...but...eh
Old Oct 14, 2011 | 10:29 AM
  #38
mileycyrus's Avatar
AND...i keep seeing this car with a cone air filter right on the MAF tube...if the sensor is that sensitive how can that work....and it seems to.....so opening up my stock box should be ok...??
http://volvospeed.com/vs_forum/topic...roject-thread/
Old Oct 15, 2011 | 10:01 AM
  #39
mileycyrus's Avatar
drove home again last night....its getting worse....cleaned everything i can see....no difference....
Old Oct 15, 2011 | 10:20 AM
  #40
Read codes.
