Low Beam Headlight not working
Old Jun 16, 2008 | 09:19 PM
Mr.Chips's Avatar
Default Low Beam Headlight not working
1995 960.
Baught a new Low Beam bulb at Auto Zone (AZ) and it won't light. Checked socket and it shiws 13 Volts. Checked bulb and it is OK.
The contacts on the bulb look really thin, went back to AZ and they checked and it was the correct bulb per them.
Could the socket contacts be sprung?
Or does it take a special bulb.
Sorry I don't remember the bulb no.
Old Jun 17, 2008 | 08:27 AM
Mr.Chips's Avatar
Default RE: Low Beam Headlight not working
This morning I switched the bulb to the other side and the bulb worked in the other side and the bulbs look the same as far as the thin metal pins were concerned.
Tried bending the metal pins in and out and they still dont make contact.
Verified the voltage and it is still 13V. Hmmmmm
The connector must not be touching the metal pins. Are these connectors available in a standard auto parts?
Help
Old Aug 5, 2008 | 02:52 PM
4ofHearts's Avatar
If you don't care about doing a little soldering you can probable cut a connector off of basicly any part of another volvo 960 from a junkyard. Almost every connector is the same for them. If I remember last time I saw under the hood of a 95, they only had 2 prongs...so I would strip a small section of the wire and jumper into that with a new connector. All in all, whatever is most convenient for you is probably what you want to do.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
tsc1015
Aug 28, 2015 10:23 AM
bomba
Jan 26, 2013 09:41 PM
Volvoguy505
Sep 11, 2010 05:53 PM
adame780
Aug 26, 2005 08:30 PM
