Left low beam headlight not coming on
Old Jan 24, 2012 | 12:27 AM
bomba's Avatar
Default Left low beam headlight not coming on
On my 2000 S40, the left low beam headlamp will not turn on. The fuse and the bulb are good. Any other known causes?
Old Jan 24, 2012 | 07:23 AM
tr_car_nut's Avatar
Get out the VOM and check for voltage at the bulb connection. One of my lamps stopped working and I found that the wiring inside the headlight had burned up. You could wiggle the connection to the low beam and it would come on but as soon as you ran over a bump it would fail. I had to pull the headlight out of the car and rewire the low beam. I pulled the connector and some wire from a 1993 Volvo 940 in the junk yard. I then cut out about six inches of the old wire and used wire caps to connect the new wire to the old wire inside the headlight. Worked great and was free to repair.
Old Jan 26, 2013 | 09:41 PM
Johnny Hamm's Avatar
Bomba
Experiencing identical fault on my 2000 s40. Lamp (bulb) and fuses check out on my VOM. How did you resolve your issue?
The three terminal connector is not getting current to the low beam left side, which could be a dreaded wiring harness issue. I am getting current to the line side of the appropiate fuse, and I jumpered (bypassed) said fuse but still no current downstream. I am a Journeyman Electrician, and I cannot explain how maddening this is....
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
Volvoguy505
Sep 11, 2010 05:53 PM
volvo40_2k
Jul 28, 2009 09:18 PM
Mr.Chips
Aug 5, 2008 02:52 PM
nicolaselias
Feb 28, 2008 08:23 PM
