LS swapped 92 960. How would YOU fix the speedo?
Old Aug 26, 2022 | 10:21 PM
gpzTurbo's Avatar
Default LS swapped 92 960. How would YOU fix the speedo?
The swap went very well. I've been driving it everywhere for 18mo. The speedo started bouncing for a few weeks then it quit.
I replaced the sensor in the rear diff just because it was easy. That didn't fix it.
I can either:
1. go through the headache of converting the wiring for the 95 cluster I have not knowing if that will fix it
2. Install a Summit or similar GPS speedo
3. Find the speed sensor on the GM trans (4l60e) and install a compatible speedo
4. some other solution I haven't thought of
What would you do ?
Old Aug 27, 2022 | 11:39 AM
Volvo 960 service & repair manual is a good resource to start with. This shows the ABS set up including the rear diff speed sensor. Was the speedo working prior to the swap?
Old Aug 27, 2022 | 11:42 AM
gpzTurbo's Avatar
Yes, speedo worked prior to and after the swap. Thanks for the link
25LikeMe960
Jul 20, 2021 12:36 PM
Mndz
Jan 9, 2014 04:30 AM
rich nc
Jan 28, 2010 07:25 PM
avinash
Jan 18, 2010 06:24 PM
dalemeetswall
Nov 15, 2006 09:04 PM
