Manual Trans Fluid....
Old Sep 27, 2005 | 10:38 PM
forrestkk's Avatar
Default Manual Trans Fluid....
Okay, I've searched a lot, and I know that the 4 speed with electric over drive uses ATF. It is the same as my Mustang, but I'm curious if the electric over drive has a filter and if it needs to be drained and changed separately. I was looking at it today and it looks like the e overdrive has a little tiny pan on it like a regular auto.
Any help would be greatly appreciate.
Thanks,
Kevin
Old Sep 28, 2005 | 01:18 AM
Default RE: Manual Trans Fluid....
I will try to find out tomorrow.
What year Stang do you have?
Old Sep 29, 2005 | 12:46 PM
forrestkk's Avatar
1990 GT I have 2000 Lightning also
Old Sep 29, 2005 | 09:29 PM
Sweet do you have alot done to it?
Old Oct 1, 2005 | 02:10 PM
forrestkk's Avatar
The mustang just has long tubes, under drive pulleys, and 4.10's. The Lightning is running 14lbs of boost, PSP 4 way chip, 90 MM MAF, Factory Tech Valve Body and shift kit, Truck Traks, PSP High Flow air filter, twin 155 lph fuel pump. An electric water pump and fan are soon to come.
I'm taking the Mustang a part this winter as it has 180k on the original motor and trans and rebuilding it from top to bottom.
Old Oct 2, 2005 | 12:11 AM
That is cool. My factory engine has 150,000 on it and has been sitting on an engine stand in my garage for a year now.
I have a Non Ho in there now for the daily driver once I buy the aftermarket Clutch Quardarant.The stock one just blew apart on me.
Money tight after being out of work almost a year and having 4 kids.
Just got back to work and starting to make money.
Here is one pic of it in color.
I have more on a disk but the computer is messing up at the moment.
[IMG]local://upfiles/853/9FCBE0BDC968434583B3A6DCC7B3697D.jpg[/IMG]
Old Oct 2, 2005 | 01:40 AM
forrestkk's Avatar
I wish I had a notch back. They are hard to come by now days. I just blew my clutch quadrant 3 weeks ago...I have an aftermarket setup, but I only changed the cable when I changed clutch. I was to lazy to mess with the quadrant, now I said forget it and will just replace it when I rip the interior out. It's funny a bad heatr core and a quadrant made me decide to rebuild the whole thing.
Old Oct 2, 2005 | 12:48 PM
I did my heater core about a year and a half ago.It was a pain in the A**.
Im hoping to get it going soon I miss driving it.That car is my baby.
Old Oct 2, 2005 | 11:42 PM
forrestkk's Avatar
I miss driving mine, and probably will for the next two years. It will be worth it when it is done though. I can't wait to get rid of my stupid turbine rims!! I'll be parting out a lot of stuff that I'm replacing, let me know if your looking for anything in particular
Old Oct 3, 2005 | 12:37 AM
I will do that thanks.
Thank god the turbine rims were gone from my car when I bought it.
I really hate them.
But another delima for me is wether to buy 4 lug 17's or convert to 5 then buy 17's.
Old Oct 3, 2005 | 09:48 PM
forrestkk's Avatar
I am thinking about the same thing. I am replacing my 8.8 and going with a 9" so I think I will probably go the 5 lug route, the fronts are easy enough with new rotors so it shouldn't be to bad, but if I wasn't changing my rear end I would probably stay with the 4 lugs. They can handle a lot of power. It's tough to spend money unless you want to see 11's.
Old Oct 4, 2005 | 08:33 PM
I hear you.I think if Im gonna do the swap im goinna do it the cheap way.
2 left side ranger axles and drums.Then for the rotors Mark 8 rotors will work but not let the center caps for some rims fit. But 100-150 instead of the full convert kit is good.
Old Oct 4, 2005 | 11:03 PM
forrestkk's Avatar
Yeah, that makes it a lot more palatable. Will the 5 star center caps not fit or is it all rims?
Old Oct 5, 2005 | 12:30 AM
IM not sure exactly which rims they will not fit on.
I know there is some but not all that will not fit.
I was going to guess when I did it.
I have a set of 5 lug 15's from a 2001 stang I was going to try when I did the conversion and see what happened.
The I was going to try the 5 star newer one with the grey center the 17's.
Old Oct 6, 2005 | 12:09 AM
forrestkk's Avatar
I don't know anybody that has converted to 5 lugs the cheap way. I'll be interested to see how it goes for you. I probably will get a 5 lug setup when I get the 9" and then get some new rotors. No sense in half assing when I'm re-doing everything.
Old Oct 6, 2005 | 12:54 AM
I hear you good luck.
Mine will take a while till I do it though.
nortons
Feb 22, 2015 11:14 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
NSF Ed
Feb 21, 2006 07:11 PM
