Oil light is on..
Old Jan 23, 2011 | 08:56 AM
scorpius's Avatar
Default Oil light is on..
Since I bought this car the Oil Light has been on, the levels are fine, and I changed the Oil and Filter and the light is still on....whats the dilly on the light...? thanx
Old Jan 23, 2011 | 11:19 AM
kendogg's Avatar
It's an oil pressure light - your owners manual should have told you this. STOP DRIVING IT until you can verify oil pressure. If you have low (or no) oil pressure, you're quickly destroying your engine.
Old Jan 23, 2011 | 11:30 AM
need2fix's Avatar
depending on the year of the car . most of the time it is the oil pick tube seals worn causing air to be sucked up instead of oil . but would start with oil press. test first
Old Jan 23, 2011 | 09:24 PM
There could also be an oil sending unit wire broken. This is just a wild guess though. I had a guy brake a wire on one when I had a 740. This caused the oil light to come on.
nuclearseal
Aug 17, 2022 01:48 PM
endneu913
Nov 21, 2010 10:53 AM
glull
Jul 17, 2008 10:51 PM
Jack
Jul 1, 2008 06:15 PM
