Rear hub removal for 89 760 IRS for dust sheild replacement.
Have to get replace the brake dust shield. Only path appears to require
popping the rear wheel hub.
From what I tell, I will need a 36mm socket and slide hammer. Will
the removing the hub damage the wheel bearing?
I was also told to put the hub in the freezer before reinstalling so it
will fit easier in to wheel bearing.
When I reinsert the hub, do I just tap it in gently and let the hub nut
get the right seating?
TERINASSsydwayz
09-28-2010 10:30 AM
