PnP switch failing
Old Nov 21, 2007 | 01:28 PM
960 rookie's Avatar
Default PnP switch failing
Hello all-
I have the P0750 code, which indicates my PnP switch is failing.....I noticed today that I don't seem to have reverse lights, (had them last week) so I am assuming that this is just another symptom of the failing switch?
Thanks-
Brady
Old Nov 26, 2007 | 12:03 PM
Default RE: PnP switch failing
Yes that is a common symptom of the switch failing.
Old Nov 28, 2007 | 07:51 PM
rob960's Avatar
Mine was doing the same thing and even got to limp mode. It was the easiest fix I have ever done. All I did to fix it was turn the key on and then shift from park to low about 20 times. It cleans the contacts and can sometimes refresh them. It cleared the code on it's own after that. It stayed off for about a week so I figured it was good, but I wanted insurance. I put it up on ramps and sprayed it with MAF cleaner and shifted it a couple of more times.
Old Nov 29, 2007 | 10:57 AM
960 rookie's Avatar
Thanks for the input. I have read on other forums that some folks have taken it apart, cleaned all the old grease out, and replaced it with new grease. Apparently that works, but I'm wondering if you go to all the trouble to remove it, if it's not just better to replace it with a new one. Obviously you save the money by re-using it, but does anyone know what the life-span would be on a cleaned one?
Old Nov 29, 2007 | 06:16 PM
I would just replace.
polepass
2001-2013 model year V70
Nov 10, 2014 01:38 AM
91shelby
Sep 29, 2011 10:04 PM
rich850
Aug 30, 2006 08:13 PM
waldos960
Jan 3, 2006 09:01 PM
tipp80
Jul 20, 2005 05:31 PM
