Shift indicator light
Hello,
How do I change the shift indicator bulb in a 97 960? If I must remove center console, I will need directions. Also need to change one bulb behind speedometer. Need directions for this too. Thanks, John
This post has instructions on getting to the bulb. https://volvoforums.com/forum/showpo...22&postcount=6
As for the bulb behand the instrument cluster, you will have to remove the panel under the dash and try to reach up and get to it. Has a couple of screws under the dash, a stud in the center side and that panel pulls out.
) Where do I get the bulb for this? Thanks,
