1997 Volvo 960 - Where is the EGR valve and vacuum control solenoid...
The P0410 code is for the Secondary Air injection, Bad Air Pump & SAS Valve - PO410 - Secondary Air - Volvospeed Forums
Boy that thread went on forever. I believe I did find all of the componets in the secondary air system. I decided to go to FCP and fish through their parts as if I was going to purchase all of them. The only one I had a hard time finding today was the EGR. It is actually located almost next to the brake fluid res.
I took some car cleaner and sprayed out everything involved and will see if that does the trick.
No, I wish. I was working on one for a lady.
I'm trying to pick up a S70 today. The lady is down to $500. She overheated the car and now they can't get it started. The top radiator hose was blown. I think it's either flooded or the head gasket is blown. I never took a motor apart like that (head gasket job). I think I'm going to do a compression test on it and decide what I'm going to do with it from there. I think it will have poor/bad compression if they blew the head gasket or messed up something in the motor.
am12eaz
05-12-2022 09:07 AM
